Manual checksum verification of CFM0
There might be some confusion here:
Checksum : configuration data checksum, reflect the contents that actually downloaded/configured into CFM. Any changes to the bitstream will change checksum. Usage to detect corruption or mismatch in configuration data.
Usercode : it is NOT the checksum of the POF file. Quartus may default it to something static or left constant. Usercode remains identical is expected behavior. Usage to version tagging/design identification/JTAG bases system identification.
regards,
Farabi
Cool, that sounds right to me. Do you have any ideas about the method that those checksums are calculated? My guess is that they seem like simple sums of a range of data, but I don't know the correct ranges or word sizes to add up.
- Farabi_Altera2 months ago
I am soryy, this information is treated as confidential. This is built-in inside the Quartus Programmer engine.
Quartus Programmer calculates the checksum by performing a simple byte-wise summation of the binary configuration data programmed to the device, excluding metadata. You can confirm this number by refer to the generated map file.
regards,
Farabi
