hariprasathb
6 months agoLVDS TX/RX Pin Assignment Error in Quartus – Unable to Resolve
Hi Team, I am facing a pin assignment issue with LVDS TX and RX IP in Quartus Prime. I have tried all the suggestions provided earlier (bank selection, I/O standard, refclk, PLL connections, and...
AqidAyman_Altera
6 months agoHi Hari,
Can you try to remove all the pin assignments?
If this passes the compilation, then you should follow the pin placement suggested by the fitter, and then it should be good.
It might be the issue with your differential pin and PLL pin placement. Refer guideline below:
https://docs.altera.com/r/docs/721819/25.3.1/agilextm-7-lvds-serdes-user-guide-f-series-and-i-series/pin-placement-for-differential-channels
Aqid
