16 years ago
LVDS resistor termination in Cyclone III
I have a design with 2 FPGA (EP3C16F484) linked together with a set of LVDS line.
I use pins in bank 1, 2, 5 an 6.
Should I place a 100ohms resistors on the receiver side, or is it included in the FPGA?
(I have search for this information in datasheet. I have undersand there is no need for resistor on transmitter, but nothing really accurate on receiver side)
    --- Quote Start ---
    --- Quote End ---
    Yes. The hardware manual is clear about this point.
    Thanks for answering.
    Please could you told me where the hardware manual is clear (is that on page 7-27)?
    I have miss something... and I want to read it carefully.
    --- Quote Start ---
    --- Quote End ---
    Page 6-20 of the cyclone III handbook:
    The LVDS standard does not require an input reference voltage, but it does require a
    100-Ω termination resistor between the two signals at the input buffer. An external
    resistor network is required on the transmitter side for top and bottom I/O banks.
    Page 7-8 of the cyclone III handbook:designing with lvds
    Cyclone III device family I/O banks support LVDS I/O standard. The left and right
    I/O banks support true LVDS transmitters. On the top and bottom I/O banks, the
    emulated LVDS transmitters are supported using two single-ended output buffers
    with external resistors. One of the single-ended output buffers is programmed to have
    opposite polarity. The LVDS receiver requires an external 100-Ω termination resistor
    Success, Ton
    Hello I am Miguel and working on FPGAs for 4 years.
    I recently found an doubt that I ant to confirm:
    All IO banksfrom Cyclone 3 have dedicated LVDS RECEIVERS and only 1, 2, 5 and 6 have DEDICATED LVDS Transmitters right???
    Thank you in advance.
    --- Quote Start ---
    Page 6-20 of the cyclone III handbook:The LVDS standard does not require an input reference voltage, but it does require a
    Success, Ton
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    Right. Best explained in C-III Device handbook chapter 7: http://www.altera.com/literature/hb/cyc3/cyc3_ciii51008.pdf
