16 years agoLVDS resistor termination in Cyclone III
Hello, I have a design with 2 FPGA (EP3C16F484) linked together with a set of LVDS line. I use pins in bank 1, 2, 5 an 6. Should I place a 100ohms resistors on the receiver side, or is it i...
12 years agoHello I am Miguel and working on FPGAs for 4 years.
I recently found an doubt that I ant to confirm: All IO banksfrom Cyclone 3 have dedicated LVDS RECEIVERS and only 1, 2, 5 and 6 have DEDICATED LVDS Transmitters right??? Thank you in advance. Regards --- Quote Start --- Page 6-20 of the cyclone III handbook:The LVDS standard does not require an input reference voltage, but it does require a 100-Ω termination resistor between the two signals at the input buffer. An external resistor network is required on the transmitter side for top and bottom I/O banks. Page 7-8 of the cyclone III handbook:designing with lvds Cyclone III device family I/O banks support LVDS I/O standard. The left and right I/O banks support true LVDS transmitters. On the top and bottom I/O banks, the emulated LVDS transmitters are supported using two single-ended output buffers with external resistors. One of the single-ended output buffers is programmed to have opposite polarity. The LVDS receiver requires an external 100-Ω termination resistor between the two signals at the input buffer. Success, Ton --- Quote End ---
