LTC Connector DE10-Standard FPGA
Hi Kian,
I was wondering if you got a chance to have a look into this.
Any help would be highly appreciated!
Hi greenlantern01,
Really sorry for the delay in getting back, was going through my mails after back to office , missed out on the notification.
From the screenshot, seems it is resetting during kernel loading stage, probably some settings in the dts.
I was checking back on Terasic schematic and notice that there is some differences between DE10-Standard Rev C and Rev D board. Could you help confirm you board revision ( i suppose to be rev C because in schematic I still see the digital accelerometer and HPS_LTC_GPIO connected to TS3A5018, Rev D schematic all these been removed)
Anyway if you're on Rev C, disregard the DTS changes you made first, and
1. Measure the HPS_LTC_GPIO ( can probe R306 resistor and check whether it toggles or switch just to check the pin logic )
I got this from the TS3A5018 datasheet (but the table here seems to indicate the other way round for NO/NC)
From schematic, Gsensor/ digital accelerometer is connected to I2C1 which looks like it is connected to different pin all together , not via TS3A5018 , thus you always can talk to Gsensor regardless of the LTG connector.
After verifying the LTC_GPIO toggles correctly, probably can check whether Linux side have these i2C drivers already initialized, if yes maybe no need add the i2c2 in the DTS for linux-socfpga
Try this command to list the i2c : i2cdetect -l
You should see something like Synopsys DesignWare
scan the bus to see whether gsensor and your ltc shows up
i2cdetect -y -r <bus number from the list, 0,1,2>
This one to confirm that i2c has gsensor and your LTC device connected.
Kian
- greenlantern016 months ago
Hello Kian,
Thank you for your response.
- It is revision C. However, it seems I've been referring to the schematics of rev b all this time. I could find only rev b schematics on the Terasic website. Could direct me to where I could find data on rev c boards?
- I wrote a c code for toggling the GPIO and probed the R306, however, there's no change. It doesn't toggle. It stays high.
- When scanning the i2c bus, I see 0x53 which is the g-sensor since that is its device address. I don't see LTC connector.
- KianHinT_altera6 months ago
Hi greenlantern01,
You can get the schematic from the DE10-standard cd rom from this link https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1081&PartNo=4#contents
In the zip folder there is a folder "Schematic" which contains both Rev C and Rev D schematic.
You will need to register an account with Terasic though before you can download.
Kian
- KianHinT_altera5 months ago
Hi greenlantern01,
Regarding the GPIO toggling not working , probably you can check whether R306 is the same placement as per rev C. Unfortunately i dont have Rev B schematic so cannot confirm on this whether the connections are the same with Rev C.
Probably you will need to toggle the LTC first before can use the i2cdetect.
Kian
- greenlantern015 months ago
Hi Kian,
The board I am using is Rev C. I have tried doing the following steps to be able to toggle the HPS_LTC_GPIO:
- Verified the HDL file connections.
2. Checked the Pin Planner to confirm if I am connecting to the correct I2C bus.
3. I generated the rbf file from the sof_to_rbf generator and saved it on the memory card which has angstrom on it.
4. I have attached the C code that I used to toggle the HPS_LTC_GPIO.
5. i2cdetect -l output:
6. i2cdetect -y -r 0 output:
I have shared the DTS file changes previously, however when trying to boot the FPGA after those changes the FPGA crashes.
Despite these process I am still not able to toggle. Kindly advice on next steps.
