14 years agoloop in VHDL
Hi, I have a question. now there are 3 vector connect with AND gate like this:
C(3)<= A(4) and B(3) C(2)<= A(4)and A(3)and B(2) C(1)<= A(4)and A(3)andA(2)and B(1) C(0)<= A(4)and A(3)andA(2)andA(1)B(0) How can I use loop to describe it?6 Replies
I think something like that would do the trick
Yes the nested loops ides is the right one, you just need to initialize the variable and use it recursively in the inside loop. Don't forget to declare the variable in the process.for i in 0 to n - 1 loop a_res := a(n); for j in i + 1 to n - 1 loop a_res := a_res and a(j); end loop; c(i) <= a_res and b(i); end loop; - Altera_Forum
Try something like that
But be aware that it's untested code. You've to verify it. :) edit: That's definitely not it! :( But I think you've to use nested loops...for i in 0 to n - 1 loop for j in i + 2 to n loop a_res := a(j) and a(j - 1); end loop; c(i) <= a_res and b(i); end loop; - Altera_Forum
--- Quote Start --- with generic code, like: C(n-1)<= A(n) and B(n-1) C(n-2)<= A(n)and A(n-1)and B(n-2) ...... C(0)<= A(n)and A(n-1)......and A(1)B(0). upstair is a example for n=4 --- Quote End --- BTW: What does A(1)B(1) mean? - Altera_Forum
--- Quote Start --- Do you want to write generic code or do you simply want to use a loop construct on the actual code you've posted? Using a loop construct on your actual code will make it worse imho. --- Quote End --- with generic code, like: C(n-1)<= A(n) and B(n-1) C(n-2)<= A(n)and A(n-1)and B(n-2) ...... C(0)<= A(n)and A(n-1)......and A(1)B(0). upstair is a example for n=4 - Altera_Forum
