17 years ago
Linux Installation Problems
I'm trying to install Quartus II on Ubuntu 8.04 using "90_altera_webinstall.sh"
The installation wizard gets to installing "Nios II Embedded Design Suite" and I get the pop up;
External program failed: /tmp/altera_9.0/linux/nios2eds/install -f /opt/altera9.0
I exit the installation wizard and try to run the installation script manually in a Terminal and I get;
./install: 44: Syntax error: "(" unexpected (expecting "fi")
Any help?? :confused:
    --- Quote Start ---
    /opt/altera7.2/quartus/bin/quartus
    --- Quote End ---
    At the end of the quartus installer wizard (90_altera_webinstall.sh), I get the option of loading Quartus and it loads up.
    I know the software has installed correctly but I just can't load it!
    Running the comment quoted above, I get;
    bash: /opt/altera7.2/quartus/bin/quartus: No such file or directory
    Thanks for the info
    I've only been using Linux for 6 months, I'm still learning....... ;)
    Using Linux without understanding a shell (tcsh, csh, bash, ksh, zsh, etc.) is like cooking without a pan. You should really get yourself a good book on Linux/Unix, in general. I like the books by Mr. Sobell....here: http://www.sobell.com/
    I've also attached an environment setup script (for "sh"-like shells: bash, Bourne shell, zsh, etc.) that I've used successfully for years. You'll have to modify it to suit your needs, but it should be relatively straightforward.
    - It's attached as a ".txt" file because of forum post restrictions...you'll want to rename this.
    Cheers,
    - Brendan
    --- Quote Start ---
    did you export QUARTUS_ROOTDIR?
    QUARTUS_ROOTDIR=/opt/altera7.2/quartus
    --- Quote End ---
    How do I do that?
    in fact, in your case it's
    --- Quote Start ---
    There is not icons on applications launch menu.
    Quartus II doesn't know the linux distro. or window manager (GNOME, KDE) used in the target system. However, you can add a new menu item in Ubuntu by doing:
    system->preferences->Main Menu
    New Item: Select "application in terminal", choose a custom name,
    and if you have installed Quartus at /opt/altera9.0/ then put at command field:
    /opt/altera9.0/quartus/bin/quartus
    --- Quote End ---
    That's what I thought, but I get this;
    dan@dan-laptop:~$ /opt/altera9.0/quartus/bin/quartus
    /opt/altera7.2/quartus7.2/adm/qenv.csh: No such file or directory.
    :mad:
    Hey thanks, that worked a treat!!
    I have another question now, where is the 'start menu' icon located?
    Usually there in the bin folder of a program but I can't find it this time
    Any ideas??? :confused:
    --- Quote Start ---
    doe's "bash" is the shell?
    --- Quote End ---
    parrado's right. Not having tcsh or having "dash" linked as the standard "/bin/sh" could cause something like what you're seeing. "dash", by the way, is the default for Ubuntu systems.
    did you install tcsh?
    sudo apt-get install tcsh
    sudo rm /bin/sh
    sudo ln -s bash /bin/sh
