17 years agoLinux Installation Problems
I'm trying to install Quartus II on Ubuntu 8.04 using "90_altera_webinstall.sh" The installation wizard gets to installing "Nios II Embedded Design Suite" and I get the pop up; External pr...
17 years ago --- Quote Start --- There is not icons on applications launch menu. Quartus II doesn't know the linux distro. or window manager (GNOME, KDE) used in the target system. However, you can add a new menu item in Ubuntu by doing: system->preferences->Main Menu New Item: Select "application in terminal", choose a custom name, and if you have installed Quartus at /opt/altera9.0/ then put at command field: /opt/altera9.0/quartus/bin/quartus --- Quote End --- That's what I thought, but I get this; dan@dan-laptop:~$ /opt/altera9.0/quartus/bin/quartus /opt/altera7.2/quartus7.2/adm/qenv.csh: No such file or directory. :mad:
