17 years agoLinux Installation Problems
I'm trying to install Quartus II on Ubuntu 8.04 using "90_altera_webinstall.sh" The installation wizard gets to installing "Nios II Embedded Design Suite" and I get the pop up; External pr...
17 years agoThere is not icons on applications launch menu.
Quartus II doesn't know the linux distro. or window manager (GNOME, KDE) used in the target system. However, you can add a new menu item in Ubuntu by doing: system->preferences->Main Menu New Item: Select "application in terminal", choose a custom name, and if you have installed Quartus at /opt/altera9.0/ then put at command field: /opt/altera9.0/quartus/bin/quartus
