19 years ago
LED drivers in MAXII
Does anyone know which IO pins are associated with ground/vcc groups in a MAXII device for use as a LED driver?
    One more thing to note - run the electro-migration current option in Quartus to ensure that you are not in violation of the current spec for each group. Put the electro-migration current assignment with a value of the static current the pin will drive for each pin driving LEDs or other resistive loads. This way, Quartus will check your pinout against the current density restrictions.
    You need to look at the max II's full pin-out file on the web to see this. The Pin/Pad function column shows you where the GNDIO pads (or VCCIO pads) are relative to IO pads. Any group of IO pads between any GNDIO pads constitute a current group that must not violate the current shown in AN 286 - table 3.
    For each IO pad in the pin/pad function column, you'll have to scroll over in the same pin-out row to see the package pin it corresponds to for the package you are using. Many I/O pads may not bond out to the package pin.
