19 years agoLED drivers in MAXII
Does anyone know which IO pins are associated with ground/vcc groups in a MAXII device for use as a LED driver?
19 years agoYou need to look at the max II's full pin-out file on the web to see this. The Pin/Pad function column shows you where the GNDIO pads (or VCCIO pads) are relative to IO pads. Any group of IO pads between any GNDIO pads constitute a current group that must not violate the current shown in AN 286 - table 3.
For each IO pad in the pin/pad function column, you'll have to scroll over in the same pin-out row to see the package pin it corresponds to for the package you are using. Many I/O pads may not bond out to the package pin.
