19 years agoLED drivers in MAXII
Does anyone know which IO pins are associated with ground/vcc groups in a MAXII device for use as a LED driver?
19 years agoOne more thing to note - run the electro-migration current option in Quartus to ensure that you are not in violation of the current spec for each group. Put the electro-migration current assignment with a value of the static current the pin will drive for each pin driving LEDs or other resistive loads. This way, Quartus will check your pinout against the current density restrictions.
