8 years ago
JTAG timing constraints
Over the years my company has made many Altera FPGA designs, and for a long time the way-of-work for JTAG constraints remained undefined and of little consequence. Then for a couple Arria V designs, JTAG instability became a hot issue (e.g. random failures when discovering the JTAG chain, using SignalTap, using SystemConsole). Our initial strategy probably was to not constrain JTAG at all (as JTAG is 'slow' and its logic is fixed), but then we would get Quartus errors regarding unconstrained ports/clocks. We then tried to find constraints recommended directly by Altera, but never could find a conclusive, complete, satisfactory answer. Based on experience we do feel that the constraints actually affect JTAG stability, and so we're still keeping an eye out for a good solution. Note that the JTAG hardware part for our designs was always rather basic, so we don't think the instability originates from there.
A selection of the examples and best practices we have found and tried over the years:
- Old TimeQuest cookbook: can't find it anymore
- Recent TimeQuest cookbook: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_timequest_cookbook.pdf
- Knowledge base item 1: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd07182016_788.html
- Knowledge base item 2: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04282008_867.html
- Forum post: https://www.alteraforum.com/forum/showthread.php?t=56328
Some of these examples seem to contradict each other, adding to the confusion.
My specific questions for Altera are:
1) What are the JTAG constraints recommended by Altera?
2) Are there any plans regarding JTAG constraints? E.g. having Quartus automatically implement them?
3) Are there any known JTAG issues for the Arria V family? If there are, are these fixed in the 10 series?
Daniel
    OP (with the Arria V) reporting in.
    --- Quote Start ---
    I wonder if there's been any further progress or a 'definite conclusion' on this matter?
    --- Quote End ---
    I made a separate support ticket for this issue; Altera's response can be summarized as follows:
    Our strategy is to try out these new constraints on future designs. We haven't gotten around to testing them on the affected design. Thus no progress or definite conclusion from our side.
    Hello Anand,
    Thanks for trying to help.
    1. JTAGEN on both boards is pulled up (10K to 3.3V)
    2. All three pins pulled up to 2.5V using 10K Res. (They are on bank 8, where the VCCIO is 2.5V I referred sec 1.1.2 of the Max 10 'Pin connection guidelines' document)
    3. TDI and TMS also pulled up by 10K but to 2.5V, as per the same sec 1.1.2 of the 'Pin connection guidelines' document. (I did not use diodes / caps on the JTAG lines (on either of the documents) to prevent 'voltage overshoot' problem, since as per the documents it is recommended, when JTAG supply is over 2.5V)
    4. CONF_DONE also stays low, along with nStatus. Only nConfig goes high, which is expected.
    5. I followed 'Pin connection guidelines', the 'Max 10 Design Guidelines' and the 'Board Design Guidelines AN114' documents, for both the boards.
    6a) I just tried loading the 'sof' file and it got loaded on the very first attempt! Here's the message I get..
    "info (209060): started programmer operation at wed dec 06 09:34:30 2017
    info (209016): configuring device index 1
    info (209017): device 1 contains jtag id code 0x031820dd
    info (209007): configuration succeeded -- 1 device(s) configured
    info (209011): successfully performed operation(s)
    info (209061): ended programmer operation at wed dec 06 09:34:31 2017"
    6b) However I really need to load the POF file and this is the message I am still getting...
    lo and behold.. I got it configured the first time using the POF file!!
    I am using the 'exact same' setup I used yesterday evening before leaving work. Did not even move a wire, except for plugging the power connector back on! I only started with the SOF file today (which I never tried on this newer board), before the POF file.
    So there's something really erratic / intermittent, which is bad as these boards are for commercial use!!
    This is very similar to the comments posted at the start of this post, that JTAG configuration reliability is becoming erratic :-| !
    This person (daniel@3t.nl) stated.. “jtag instability became a hot issue (e.g. random failures when discovering the jtag chain, using signaltap, using systemconsole).”
    For the past two days, when using the POF file, I would only read the Device ID and then get error message something like "Error 16328: Put the device in User mode .."
    Unfortunately I had to clear my browser cache and don't recall the exact message. If it re-appears I would post it.
    Hello Anand,
    The person (daniel@3t.nl) stated.. “jtag instability became a hot issue (e.g. random failures when discovering the jtag chain, using signaltap, using systemconsole).”
    For the past two days, when using the POF file, I would only read the Device ID and then get error message something like "Error 16328: Put the device in User mode …"
    Hello Anand,
    On my second board, I tried the SOF first and it programmed without any issue, on the first attempt itself.
    On trying the POF file, I got the following message..
    Info (209060): Started Programmer operation at Wed Dec 06 17:04:27 2017
    Info (209017): Device 1 contains JTAG ID code 0x031820DD
    Info (209044): Erasing MAX 10 configuration device(s)
    Info (209023): Programming device(s)
    Info (209021): Performing verification on device(s)
    Error (209048): Verify failure on device number 1
    Error (209012): operation failed (83% on the 'Progress' bar)
    Info (209061): Ended Programmer operation at Wed Dec 06 17:07:13 2017
    On trying again, I get following message right away, as before...
    Info (209060): Started Programmer operation at Wed Dec 06 17:07:51 2017
    Warning (16328): The real-time ISP option for Max 10 is selected. Ensure all Max 10 devices being programmed are in user mode when requesting this programming option
    Could there be any Voltage regulation issue? I am using LM1117 chips for 2.5V and 3.3V supplies.
    Part nos are LM1117MPX-3.3/NOPB and LM1117MPX-2.5/NOPB
    Scope is showing values between 3.36 - 3.40 and 2.56 – 2.60V.
    So there is about 4mV swing / ripple on each of the supply.
    Thank you,
    --- Quote Start ---
    --- Quote End ---
    This error is because CRC mismatch.
    1.Try to DISABLE it and program. Check session 3.6.2
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/ug_m10_config.pdf
    or
    try to program using both the methods (By using on-chip ram / by using on-chip flash)
    https://www.youtube.com/watch?v=0k4azmdw9sk
    Anand Raj Shankar
