Carlhermann
9 months agoJTAG Test SW Issue (JTAG TopProbe)
Hi, I used JTAG TopProbe als Boundary Scan SW to change / read level at FPGA pins in the past successfully with Cyclone II designs. Unfortunately I ran into issues with newer designs using Cyclone ...
Carlhermann
9 months agoHi,
the issue is related to the Dev.Board comes with a pre-programmed configuration.
As the USB-Blaster JTAG I/F lacks the (optional) JTAG Reset-Line, the FPGA is already on power up in "post configuration" mode, even with the JTAG-Reset command by TopJTAG. Thus, only the pins used as outputs in this configuration can be set/reset by TopJTAG.
I cleared the FLASH, thus the FPGA is now unconfigured at power up and by this all I/O pins are now controllable by TopJTAG :-)
KR
Carlhermann
Farabi_Altera
9 months agoHello,
Cool. Glad to hear your workaround works.
regards,
Farabi
