JTAG Test SW Issue (JTAG TopProbe)
which Cyclone 10 FPGA and QMTech board is it?
I also noticed comment in Cyclone 10 BSDL file, that it's only intended for testing unconfigure FPGA. With TopJTAG, I never worried about this point and had no problems to perform intended tests with Altera provided BSDL files. I already guessed that TopJTAG does the required translation, if any.
I specifically don't understand why some pins seem to require special handling.
See also Cyclone 10LP Post Configuration BSDL | Altera Community
Frank
1. Please make sure you are using latest BSDL file.
2. Please make sure you JTAG/BST logic is enabled before running EXTEST.
3. Cyclone IV GX adds IEEE 1149.6 cells for AC-coupled transceivers, which differ from standard IO cells. Please make sure the tool you are using understand those particular cells. Otherwise, it only run samples. Regular IO is using IEEE 1149.1.
regards,
Farabi
