Jcole
2 years agoIs it possible to load an image into flash via (JIC) and still be able to use Signal Tap?
Hi I'm trying to load up the flash connected to my FPGA with an image via Quartus possibly using a (JIC), and use Signal Tap to check some signal behaviour. I setup signal tap and compile the design...
- 2 years ago
If .jic image has been compiled with Signaltap, the tool will recognize the image. To be sure, you can ignore the message and start acquisition. You either succeed or get an "incompatible image" message. In the latter case, you didn't manage to put the right image into .jic.
NurAiman_M_Intel
2 years agoI’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
