Jcole
1 year agoI figured out the issues, needed to power cycle the board before it would recognise the new build loaded in the Signal Tap would be able to see the STP instance.
If .jic image has been compiled with Signaltap, the tool will recognize the image. To be sure, you can ignore the message and start acquisition. You either succeed or get an "incompatible image" message. In the latter case, you didn't manage to put the right image into .jic.
