IP components used in the design have conflicting settings. Intel PCIE Ftile MCDMA
Sorry yes I got it to work. I wanted to avoid removing all my connections so I went in to the xml and removed everything that had "core4" in it, and it built fine. It seems IP designer leaves in xml when converting between 4x4 and 1x16.
Hi BeJamIn
Thank you for the updates.
Yes, that can be used as a workaround if you prefer not to remove the existing connections.
However, the safest path is the approach to remove current MCDMA IP and regenerate a fresh MCDMA IP when changing the mode configuration to ensure all the generated files are all clean and correct.
Since the issue has been resolved, I will transition this thread to the community. If you have any new questions, please feel free to open a new thread and the Altera experts will be happy to assist.
Ven
