IP components used in the design have conflicting settings. Intel PCIE Ftile MCDMA
Hi BeJamIn
May I know if you have had a chance to review my previous message and try the proposed workaround?
Ven
Sorry yes I got it to work. I wanted to avoid removing all my connections so I went in to the xml and removed everything that had "core4" in it, and it built fine. It seems IP designer leaves in xml when converting between 4x4 and 1x16.
- VenT_Altera1 month ago
Hi BeJamIn
Thank you for the updates.
Yes, that can be used as a workaround if you prefer not to remove the existing connections.
However, the safest path is the approach to remove current MCDMA IP and regenerate a fresh MCDMA IP when changing the mode configuration to ensure all the generated files are all clean and correct.
Since the issue has been resolved, I will transition this thread to the community. If you have any new questions, please feel free to open a new thread and the Altera experts will be happy to assist.
Ven
