SK_VA's avatar
SK_VA
7 years ago
IO_OBUF Placement and IC delay in timing path
Is there anyways we can constrain the placement of IO_OBUF so that it is closer to the pad.
How can we reduce the IC delay in the timing path?
  • SK_VA's avatar
    SK_VA
    Even after using these options I am seeing the same delay from IO-OBUF to output pin.
    Sanju
  • SK_VA's avatar
    SK_VA
    I am using Cyclone IV with speed grade 8.These options are applicable for all devices and speed grades.Please suggest some document to get more information on these settings.
  • KennyT_altera's avatar
    KennyT_altera
    You can go to the chip planner -> locate the IO -> cross probe it to resource property editor.
    There you can see the delay.
    Then, go to settings -> assignment editor -> look for d4 d5 delay and tune accordingly.
  • SK_VA's avatar
    SK_VA
    Thanks for the reply.
    Can u please explain more on tuning d4 and d5 delay
    KennyT_altera
    Unfortunately no. What you can do is 1) use fast input and out register. 2) tune the d4 and d5 delay.
