15 years ago
interface code
Hello friends,
I have 2 circuits viz cir1 and cir 3. Now i want to link these 2 circuits via an independent entity say-cir2. In other words cir2 will act as a bridge between cir1 and cir3. i have independent vhdl files for both cir1 and cir3 i.e cir1.vhd and cir3.vhd. How do i write the code for cir2? How can i call the 2 circuits i.e cir1 and cir3 via the cir2 code? Pls assist me.
Vinod.
    Why have you got inputs floating?
    Usually, floating inputs will mean things wont work properly.
    Hi Sir,
    Thanks again. what i did was design cir1 and cir3 in seperate vhdl files. then i designed another vhdl file named cir2.vhd. in this i did a port map.
    In cir1 we have 3 inputs and 3 outputs. while in cir3 we have 3 i/ps and 4 o/ps.
    which implies cir2 shall have 3 i/ps and 3 o/ps. But when i do a port map i only need to map o/ps of cir1 to i/ps of cir2 and o/p of cir2 to i/p of cir3. This basically means that i/p to cir1 and o/p to cir3 will be left floating and i am unable to use the portmap statement.
    Any suggestions sir?
    --- Quote Start ---
    Hello Sir,
    Thanks for the reply. u r right they are all in different files viz cir1.vhd,cir2.vhd and cir3.vhd. Now u mentioned the entities at the top of the code for both cir1 and cir2.will i need to just declare the entities there or also the architecture as well?
    --- Quote End ---
    no, you dont need the entites at the top of cir2.vhd. They were just there to illustrate the port maps.
    --- Quote Start ---
    So basically i shall write a new code for cir3 viz- cir3.vhd and follow the steps stated by you. also, as to "entity work.cir1" - this means that we need all the 3 vhdl files in the same work directory,right sir?
    Vinod.
    --- Quote End ---
    they dont need to be the same working directory, just compiled into the same library. In VHDL the default local library is called "work".
    Hello Sir,
    Vinod.
    cir 2 is actually a wrapper around cir1 and cir3
    here is an example (Im assuming cir1/2/3 are all separate files):
    entity cir1 is
      port (
        input  : in  std_logic;
        output : out std_logic;
    end entity cir1;
    entity cir3 is
      port (
    end entity cir1;
    --To connect them:
    entity cir2
      port (
        --add ports if you need them
    end entity cir2;
    architecture struct of cir2 is
      signal cir1_to_cir3 : std_logic;
      signal cir3_to_cir1 : std_logic;
    begin
      cir1_inst : entity work.cir1
      port map (
        input  => cir3_to_cir1,
        output => cir1_to_cir3
      cir3_inst : entity work.cir3
      port map (
        input  => cir1_to_cir3,
        output => cir3_to_cir1
    end architecture struct;
