15 years agointerface code
Hello friends, I have 2 circuits viz cir1 and cir 3. Now i want to link these 2 circuits via an independent entity say-cir2. In other words cir2 will act as a bridge between cir1 and cir3. i ha...
15 years agocir 2 is actually a wrapper around cir1 and cir3
here is an example (Im assuming cir1/2/3 are all separate files):
entity cir1 is
port (
input : in std_logic;
output : out std_logic;
end entity cir1;
entity cir3 is
port (
end entity cir1;
--To connect them:
entity cir2
port (
--add ports if you need them
end entity cir2;
architecture struct of cir2 is
signal cir1_to_cir3 : std_logic;
signal cir3_to_cir1 : std_logic;
begin
cir1_inst : entity work.cir1
port map (
input => cir3_to_cir1,
output => cir1_to_cir3
cir3_inst : entity work.cir3
port map (
input => cir1_to_cir3,
output => cir3_to_cir1
end architecture struct;
