Intel Devstack-OpenCL unable to detect PAC Cards
Intel Development Acceleration Stack for OpenCL is not detecting the Arria 10 PAC Cards on our server. It's looking for PAC drivers which cannot be found at the OpenCL_BSP installation path.
The Cards can be detected using `lspci` and `OPAE drivers` but not with `aocl diagnose` command:
System Specs:
OS: ubuntu - 18.04
The following is the log:
server2@ubuntu:~$ sudo fpgainfo fme Board Management Controller, microcontroller FW version 26895 Last Power Down Cause: POK_CORE Last Reset Cause: None //****** FME ******// Object Id : 0xEE00001 PCIe s:b:d:f : 0000:AF:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x124000200000367 Bitstream Version : 1.2.4 Pr Interface Id : 38d782e3-b612-5343-b934-2433e348ac4c Boot Page : user Board Management Controller, microcontroller FW version 26895 Last Power Down Cause: POK_CORE Last Reset Cause: None //****** FME ******// Object Id : 0xEE00000 PCIe s:b:d:f : 0000:86:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x124000200000367 Bitstream Version : 1.2.4 Pr Interface Id : 38d782e3-b612-5343-b934-2433e348ac4c Boot Page : user server2@ubuntu:~$ source ~/inteldevstack/init_env.sh export QUARTUS_HOME=/opt/intelFPGA_pro/quartus_19.2.0b57/quartus export OPAE_PLATFORM_ROOT=/home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv export AOCL_BOARD_PACKAGE_ROOT=/home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp source /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec/setup_permissions.sh $OPAE_PLATFORM_ROOT/bin is in PATH already sudo cp /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/sw/afu_platform_info /usr/bin/ export INTELFPGAOCLSDKROOT=/opt/intelFPGA_pro/quartus_19.2.0b57/hld export ALTERAOCLSDKROOT=/opt/intelFPGA_pro/quartus_19.2.0b57/hld $QUARTUS_HOME/bin is in PATH already source /opt/intelFPGA_pro/quartus_19.2.0b57/hld/init_opencl.sh server2@ubuntu:~$ aocl diagnose -------------------------------------------------------------------- ICD System Diagnostics -------------------------------------------------------------------- Using the following location for ICD installation: /etc/OpenCL/vendors Found 2 icd entry at that location: /etc/OpenCL/vendors/Altera.icd /etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd the following OpenCL libraries are referenced in the icd files: libalteracl.so libintelocl_emu.so checking LD_LIBRARY_PATH for registered libraries: libalteracl.so was registered on the system at /opt/intelFPGA_pro/quartus_19.2.0b57/hld/host/linux64/lib libintelocl_emu.so was registered on the system at /opt/intelFPGA_pro/quartus_19.2.0b57/hld/host/linux64/lib Using the following location for fcd installations: /opt/Intel/OpenCL/Boards Found 2 fcd entry at that location: /opt/Intel/OpenCL/Boards/a10_ref.fcd /opt/Intel/OpenCL/Boards/dcp_bsp.fcd the following OpenCL libraries are referenced in the fcd files: /opt/intelFPGA_pro/quartus_19.2.0b57/hld/board/a10_ref/linux64/lib/libaltera_a10_ref_mmd.so /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so checking LD_LIBRARY_PATH for registered libraries: /opt/intelFPGA_pro/quartus_19.2.0b57/hld/board/a10_ref/linux64/lib/libaltera_a10_ref_mmd.so was registered on the system. /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so was registered on the system. Number of Platforms = 2 1. Intel(R) FPGA SDK for OpenCL(TM) | Intel(R) Corporation | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.4 2. Intel(R) FPGA Emulation Platform for OpenCL(TM) | Intel(R) Corporation | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2 -------------------------------------------------------------------- ICD diagnostics PASSED -------------------------------------------------------------------- -------------------------------------------------------------------- BSP Diagnostics -------------------------------------------------------------------- Error initializing DMA: no memory Error initializing mmd dma Error closing DMA Error initializing bsp Error initializing DMA: no memory Error initializing mmd dma Error closing DMA Error initializing bsp -------------------------------------------------------------------- Warning: No devices attached for package: /opt/intelFPGA_pro/quartus_19.2.0b57/hld/board/a10_ref -------------------------------------------------------------------- Unable to find the kernel mode driver. Please make sure you have properly installed the driver. To install the driver, run aocl install DIAGNOSTIC_FAILED -------------------------------------------------------------------- -------------------------------------------------------------------- Warning: No devices attached for package: /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp -------------------------------------------------------------------- Error initializing DMA: no memory Error initializing mmd dma Error closing DMA Error initializing bsp Error initializing DMA: no memory Error initializing mmd dma Error closing DMA Error initializing bsp -------------------------------------------------------------------- Call "aocl diagnose <device-names>" to run diagnose for specified devices Call "aocl diagnose all" to run diagnose for all devices server2@ubuntu:~$ aocl install Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] y aocl install: /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp is already registered in the system, please uninstall it before reinstalling server2@ubuntu:~$
Please help us fix this @intel @BoonBengT_Altera @JohnT_Intel
Thank you,
Saikiran
- Saikiranbelana
Hi @JohnT_Intel , Here's the output for lspci
server2@ubuntu:~$ lspci | grep acce af:00.0 Processing accelerators: Intel Corporation Device 09c4The FPGA is still available and only shows with lspci and fpgainfo. I think the problem is with the drivers. When I move the FPGA to a different system, It works there.
- JohnT_Altera
Can you try "lspci -vv | grep acce" to get the kernel driver information.
- Saikiranbelana
Here's the output for `lspci -vv | grep acce`:
server2@ubuntu:~$ sudo lspci -vv | grep acce af:00.0 Processing accelerators: Intel Corporation Device 09c4for `lspci -vv` :
af:00.0 Processing accelerators: Intel Corporation Device 09c4 Subsystem: Intel Corporation Device 0000 Physical Slot: 5 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin A routed to IRQ 39 NUMA node: 1 Region 0: Memory at dbffff00000 (64-bit, prefetchable) [size=512K] Region 2: Memory at dbfffe00000 (64-bit, prefetchable) [size=1M] Capabilities: [68] MSI-X: Enable+ Count=7 Masked- Vector table: BAR=0 offset=00009000 PBA: BAR=0 offset=0000a000 Capabilities: [78] Power Management version 3 Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-) Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME- Capabilities: [80] Express (v2) Endpoint, MSI 00 DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+ RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset- MaxPayload 256 bytes, MaxReadReq 4096 bytes DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend- LnkCap: Port #0, Speed 8GT/s, Width x8, ASPM not supported, Exit Latency L0s <4us, L1 <1us ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+ LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+ ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt- LnkSta: Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt- DevCap2: Completion Timeout: Range B, TimeoutDis-, LTR-, OBFF Not Supported DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis- Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS- Compliance De-emphasis: -6dB LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+ EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest- Capabilities: [100 v2] Advanced Error Reporting UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol- UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol- UESvrt: DLP- SDES+ TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol- CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr- CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr+ AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn- Capabilities: [160 v1] Alternative Routing-ID Interpretation (ARI) ARICap: MFVC- ACS-, Next Function: 0 ARICtl: MFVC- ACS-, Function Group: 0 Capabilities: [200 v1] Single Root I/O Virtualization (SR-IOV) IOVCap: Migration-, Interrupt Message Number: 000 IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy+ IOVSta: Migration- Initial VFs: 1, Total VFs: 1, Number of VFs: 0, Function Dependency Link: 00 VF offset: 1, stride: 1, Device ID: 09c5 Supported Page Size: 00000553, System Page Size: 00000001 Region 0: Memory at 00000dbfffd00000 (64-bit, prefetchable) Region 4: Memory at 00000dbffff80000 (64-bit, prefetchable) VF Migration: offset: 00000000, BIR: 0 Capabilities: [280 v1] #19 Kernel driver in use: intel-fpga-pci Kernel modules: intel_fpga_pci - JohnT_Altera
Thanks for providing the logfile. From the logfile, it looks like it automatically loaded with default PCIe driver. Please performed "modprobe -r intel-fpga-pci" then only performed "aocl install".
- JohnT_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- Saikiranbelana
Sorry for the delayed response.
I couldn't fix the error occurring. So, I had to reinstall the OS and install the inteldevstack on it. It works now.
Thanks, @JohnT_Intel for the support.
