Avinash_B_P
5 years agoIntel Cyclone 10 GX EMIF IP timing model required for DDR3 SI simulation
Hello I am running the ddrx simulation wizard with hyperlynx tool. i am DQ (data) lines are failing with setup and hold time at slow swing. for this error i wanted to run the wizard with adding tim...
Avinash_B_P
5 years agoDQ (data) lines are failing with setup and hold time at slow swing at read cycle. write cycle is good.
- yoichiK_altera5 years ago
Contributor
Hello
Timing analysis will be analyzed in the Quartus Timing Analysis. There is DDR report tab in the Timing Analysis. User only need to check the Signal Integrity of each signals by SI simulation.
