14 years ago
Initial process does not run?
Hi everyone,
I have an Initial process which assigns values to some variables, but I cannot get these variables' value in a clocked process. Anyone can help me?
    I have a single dimension array implemented in register not working:
    reg  Array ;
    initial begin
      byte i, j;
      for (i=63; i>=0; i--)
        Array = 0;
        Array = 1;
    end
    always @ (posedge PLL)
      begin
        // Array returns 1 at Array only.
      end
    I have just contacted Altera Support, but they refused to file my request because my account was not registered under a company/university name, and my e-mail address was not associated with a company/university. :(
    I could reproduce a Quartus problem with initial blocks. What I see is this:
    - If the array is implemented in registers, initial blocks like in the present example are working without limitations.
    - If the array infers RAM, initial blocks should be converted to memory initialization files, as stated in the Quartus handbook:
    --- Quote Start ---
    In Verilog HDL, you can use an initial block to initialize the contents of an inferred
    memory. Quartus II integrated synthesis automatically converts the initial block into a
    .mif for the inferred RAM. Example 6–19 shows Verilog HDL code that infers a simple
    dual-port RAM block and corresponding .mif file.
    --- Quote End ---
    This works for the given example
    module ram_with_init(
      output reg  q,
      input  d,
      input  write_address, read_address,
      input we, clk
      reg  mem ;
      integer i;
      initial begin
        for (i = 0; i < 32; i = i + 1)
          mem = i;
      end
      always @ (posedge clk) begin
        if (we)
          mem <= d;
        q <= mem;
      end
    endmodule
    But there seems to be a problem to convert multi-dimensional assignments as in your example. You can determine if the initial block has been converted correctly by reviewing the compilation messages. The INIT_FILE line will only appear if the initial block has been understood.
    --- Quote Start ---
    Info: Instantiated megafunction "altsyncram:ram_rtl_0" with the following parameter:
    Info: Parameter "INIT_FILE" = "db/test1.ram0_single_port_ram_7cbe84f1.hdl.mif"
    --- Quote End ---
    Knowing this limitation, you'll hopefully find a workaround. You also may want to report this as a bug to Altera support.
    I have created a nested loop to initial the array, but I failed to assign it's value.
    bit Array ;
    initial begin
      byte i, j;
      for (i=20; i>=0; i--)
        for (j=20; j>=0; j--)
          Array = 0;
        Array = 1;
    end
      begin
        // Array returns 0 at all elements here
      end
    Initial block will be synthesized as POR state for signals or possibly as initial values for block RAM.
    In the present case, a nested loop would be necessary to initialize the complete array, only a diagonal is initialized now.
    I am coding in SystemVerilog. Quartus does not report any syntax error, so I think the for loop structure is fine. The initial process affects some other variables except array type. :confused:
    "initial" is only used in test benches, it can not be used for code running in an FPGA.
    Although I'm not much of a verilog guy, I think the for loop is constructed incorrectly. Try
    bit Array;
    initial begin
      byte i;
      for (i=20; i>=0; i--) begin
        Array = 1;
      end
    end
      begin
        // Array value returns 0 at all elements here
      end
    The code looks like this:
    bit Array;
    initial begin
      byte i;
        Array = 1;
    end
      begin
      end
    Adding a little code here could help us help you.
    Make sure you aren't trying to assign the same variable in two separate processes.
