14 years agoInitial process does not run?
Hi everyone, I have an Initial process which assigns values to some variables, but I cannot get these variables' value in a clocked process. Anyone can help me?
14 years agoI could reproduce a Quartus problem with initial blocks. What I see is this:
- If the array is implemented in registers, initial blocks like in the present example are working without limitations. - If the array infers RAM, initial blocks should be converted to memory initialization files, as stated in the Quartus handbook: --- Quote Start --- In Verilog HDL, you can use an initial block to initialize the contents of an inferred memory. Quartus II integrated synthesis automatically converts the initial block into a .mif for the inferred RAM. Example 6–19 shows Verilog HDL code that infers a simple dual-port RAM block and corresponding .mif file. --- Quote End --- This works for the given examplemodule ram_with_init(
output reg q,
input d,
input write_address, read_address,
input we, clk
reg mem ;
integer i;
initial begin
for (i = 0; i < 32; i = i + 1)
mem = i;
end
always @ (posedge clk) begin
if (we)
mem <= d;
q <= mem;
end
endmodule But there seems to be a problem to convert multi-dimensional assignments as in your example. You can determine if the initial block has been converted correctly by reviewing the compilation messages. The INIT_FILE line will only appear if the initial block has been understood. --- Quote Start --- Info: Instantiated megafunction "altsyncram:ram_rtl_0" with the following parameter: Info: Parameter "INIT_FILE" = "db/test1.ram0_single_port_ram_7cbe84f1.hdl.mif" --- Quote End --- Knowing this limitation, you'll hopefully find a workaround. You also may want to report this as a bug to Altera support.
