17 years agoInitial DFF values after FPGA programming
Normally I design my all my logic with an asynchronous reset, so this is not an issue, but I have recently come across an area where we might reload the FPGA via nCONFIG to reset it, and not have User IO based asynchrnonous reset. In this case a DFF with enable would have the following code:
always @(posedge clk)
if(enable) q <= data; What will the value of this register be before the DFF is enabled? Is this value guaranteed? Does this act the same way across all Altera device families? What about other PLD vendors?22 Replies
in verilog you have the initial block after the modul declaration
module mymodul ( myclk , myreg); input myclk; output myreg; initial begin myreg <= myinitvalue; end reg myreg; always @ ( posedge myclk ) myreg <= myreg + 1; endmodule but have a look at the quartus settings about initial values, i am currently unshure which one but i think the is one settings about that. regards michael - Altera_Forum
See page 6-36 of the HDL coding guidelines:
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf Registers should power up with a '0' value. You can also specify a power-up value using an assignment. There is the NOT-gate pushback optimization that can change the behavior in some cases but I suspect you don't need to worry about that. Jake
