16 years agoinfer true dual port asynchronous ram
hallo everyone, i need a true dual port asynchronous ram for my selfmade soft-core project. to be hardware independent i try to infer the ram-block from vhdl-code. this is my code: ...
16 years agook...its not the best way...but now i am using the megafunctions in my vhdl description.
but at synthesis appeared an other problem. configuration of my altsyncram: - two read/write ports (true dual-port mode) - 256 words (word = 16 bits) -> 256x16 - dual clock: use seperate clocks for A and B ports - create one clock enable signal for each clock signal so the total used memory bits should be 256*16 = 4096 bits but the synthesis uses 8192 bits (2 M4Ks). is this the correct behaviour? i have not find any application note to this topic. i am using a cyclone II device edit: i have tested the megafunction with Input/Output and Single Clock mode. in both cases the synthesis uses 1 M4K cell.
