image read in vhdl
i want to read an image (or preferably a matrix of size 8x8) pixel by pixel in one clock cycle(if rising edge then read one pixel in 2nd rising edge 2nd pixel)....thanks in advance
And what is your question?
Sounds like a normal project. Whats the problem?
i have got the code to extract row wise in each clock cycle.... How to extract pixel by pixel in each clock cycle.....and store it in another matrix....
i have to do Discrete wavelet transform on images by lifting scheme. - Altera_Forum
my project is to perform discrete wavelet transform of image...for which i have to implement lifting scheme on image...which needs to extract even and odd pixels of the respective image.....
--- Quote Start --- i have got the code to extract row wise in each clock cycle.... How to extract pixel by pixel in each clock cycle.....and store it in another matrix.... i have to do Discrete wavelet transform on images by lifting scheme. --- Quote End --- Use a counter as the index into the array? Why not try and code this yourself and we can help with problems? we are not going to do your work for you... - Altera_Forum
--- Quote Start --- Use a counter as the index into the array? Why not try and code this yourself and we can help with problems? we are not going to do your work for you... --- Quote End --- i have done some modifications in the code....please help with the code
error is :package newtype is type row_t is array(0 to 3) of integer; type matrix_t is array(0 to 3, 0 to 3) of integer; type row_pixel is array (0 to 0) of integer; end newtype; --function to extract each pixels of a row function extract_row_pixel(row1 : row_t; pixel : integer) return row_pixel is variable ret_pixel : row_pixel; begin for i in 0 downto 3 loop ret_pixel(i) := row1(pixel, i);------error is Type integer is not an array type and cannot be indexed. end loop; return ret_pixel; ------error is Expecting type row_pixel for <ret_pixel>. end function; if rising_edge(clk) then temp_row_pixel <= extract_row_pixel (output, to_integer(count)); count <= count + 1; output1 <= temp_row_pixel; end if; - Altera_Forum
For a start, this is never going to work. It looks like you're trying to write sofware. This is clearly not the full code as there are lots of things missing (like a process, architecture, etity etc).
So errors in your code: row_pixel is an array of length 1. Your for loop also never executes as you have 0 downto 3 (a null range). I suggest you go back to the drawing board - literally. DRAW your intended circuit on paper before you write any VHDL. VHDL is a hardware description language. Not a programming language. Writing code like software will not work. - Altera_Forum
--- Quote Start --- For a start, this is never going to work. It looks like you're trying to write sofware. This is clearly not the full code as there are lots of things missing (like a process, architecture, etity etc). So errors in your code: row_pixel is an array of length 1. Your for loop also never executes as you have 0 downto 3 (a null range). I suggest you go back to the drawing board - literally. DRAW your intended circuit on paper before you write any VHDL. VHDL is a hardware description language. Not a programming language. Writing code like software will not work. --- Quote End ------main code package newtype is type row_t is array(0 to 3) of integer; type matrix_t is array(0 to 3, 0 to 3) of integer; type row_pixel is array (0 to 0) of integer; end newtype; library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.newtype.all; entity test is port(input: in matrix_t; clk: in std_logic; output : inout row_t; output1 : out row_pixel); end test; architecture arch of test is signal matrix : matrix_t; signal temp_row : row_t; signal temp_row_pixel : row_pixel; signal count : unsigned(1 downto 0) := "00"; --signal output: row_t; --function to extract rows function extract_row( m : matrix_t; row : integer) return row_t is variable ret : row_t; begin for i in row_t'range loop ret(i) := m(row, i); end loop; return ret; end function; --function to extract each pixels of a row function extract_row_pixel(row1 : row_t; pixel : integer) return row_pixel is variable ret_pixel : row_pixel; begin for i in 0 to 3 loop ret_pixel(i) := row1(pixel, i); end loop; return ret_pixel; end function; begin process(clk) begin if rising_edge(clk) then temp_row <= extract_row( input, to_integer(count) ); count <= count + 1; output <= temp_row; temp_row_pixel <= extract_row_pixel (output, to_integer(count)); count <= count + 1; output1 <= temp_row_pixel; end if; end process; end arch; ---testbench library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_Std.all; use work.newtype.all; entity test_tb is end; architecture bench of test_tb is component test port(input: in matrix_t; clk: in std_logic; output : inout row_t; output1 : out row_pixel); end component; signal input: matrix_t; signal clk: std_logic; signal output: row_t; signal output1 : row_pixel; constant clock_period: time := 10 ns; signal stop_the_clock: boolean; begin uut: test port map ( input => input, clk => clk , output => output, output1 => output); stimulus: process begin input <= ((0,1,2,9), (3,5,6,10), (9,8,11,2), (9,7,1,6)); wait for 50ns; stop_the_clock <= true; wait; end process; clocking: process begin while not stop_the_clock loop clk <= '1', '0' after clock_period / 2; wait for clock_period; end loop; wait; end process; end; - Altera_Forum
Why bother declaring row_pixel at all? its just an array of length 1, why not just return an integer?
Why are you using an inout for output? this is bad practice the error is here: for i in 0 to 3 loop ret_pixel(i) := row1(pixel, i); end loop; ret_pixel is a row_pixel type with a range 0 to 0. Your loop is going out of range. - Altera_Forum
And why not just the count signal to access into the image?
