15 years ago
image compression architecture for haar filter
Hello everyone..
Iam new with QuartusII software..i need help from you all..:confused:
I was design architecture for image compression using Haar filter and using pipelined technique.
As we know, Haar filter consist of 2 algorithm which are averaging and differencing.
My question is how suppose i start to write the VHDL code for the architecture? I have problem to evaluate the algorithm into VHDL code because of the - and / operations.
I appreciate your helps..
    Thanks for your respond..i get more clear know.
    Thanks for reply
    then it is quite simple to do arithmatic in VHDL, it is as simple as:
    c <= a + b;
    c <= a - b;
    c <= a * b;
    etc.
    I learn digital logic design during my degree and know i do my master focus in digital design.
    I understand to design using gate based on the equation.But know, i need to write VHDL code based on architecture.Hope you understand what i mean.
    Thank for reply..
    Building filters is probably not a great way to start with VHDL. How good are you with digital logic design?
    My problem is i dont have any idea to write the VHDL code.
    What type of architecture i need to write?..Iam very new with VHDL code..
    Thanks for reply..
    there is not problems doing subtraction in FPGAs. Divide functions you'll have to instantiate a divide megafunction - quartus cannot pipeline a divide function from infered code yet.
    So what problems are you having?
