16 years agoI can't solve the wrong with a stop watch desiging
I was designing a stop watch this week,but get some troubles.
There are four keys---reset,stop,minset(minute set),and secset(second set) in the watch.The reset and stop fuctions are right,but the minset and the secset won't make the minute or the second +1 successfully,and show some error numbers.I don't know why. This is my code: module SECLOCK(clk,sclk,rundir,key); input clk,sclk;//clk--system clk,sclk---percentage second input rundir;//run direction input[3:0] key;// 4 keys reg[32:0] j;//the total percentage seconds,to generate min,sec,percentage second reg run;//stop mark reg keyclk; reg ssclk; always @(posedge clk)//scan the keys' value,when key!=0,keyclk set high begin if(key!=0) keyclk<=1; else keyclk<=0; end always @(sclk)//avoid the conflict between keyclk and ssclk begin if(keyclk!=0) ssclk=0; else ssclk=sclk; end always @(posedge keyclk or posedge ssclk) begin if(keyclk) begin case(key0) 4'b0001://reset begin j<=0; run<=0; end 4'b0010://stop begin run<=~run; end 4'b0100://set second + 1 begin j<=j+33'd100; end 4'b1000://set min + 1 begin j<=j+33'd6000; end endcase end else begin if(run==1 && rundir==1 ) //forward count j<=j+1; else if(run==1 && rundir==0 && j>0) //reward count j<=j-1; end end endmodule6 Replies
I get it!
I used one trigger source to replace the old sources,and get successed. So interesting the end is. But I really want to know why my old codes excute exceptionally. I use the signaltap to monitor the signal,and the result is out of logic. Fvm,Thanks for your help. - Altera_Forum
four keys(posedge keyclk touch off):
(1)reset:j=0,run=0; (2)stop:run=~run; (3)sec:j=j+100; (4)min:j=j+6000; sclk:50MHz(clk)->100HZ(sclk) 1% second count(posedge sclk touch off): j=j+1;---->ssclk touch off(avoid conflict between keyclk or ssclk) I add the keyclk to the sensitivity list later(Sorry,I didn't know that error before),but have not any change. I can't understand the sentence of"you can't build a counter from latches". Can you explain it for detail. I give a .doc file,to show a successful case.If you need the project,I will send it. If the overall design is wrong ,how should I do it.I really have not any ideas now. - Altera_Forum
In Quartus synthesis, the said always@(sclk) block works as a simple conditional assignment:
But keyclk must be added to the sensitivity list to get the same result in other tools, too. I don't understand the purpose of the operation, however. Regarding the always @(posedge keyclk or posedge ssclk) block, my first comment wasn't exact. keyclk is an asynchronous reset, in so far it's legal. But you can't have expressions like j<=j+33'd100; in the asynchronous reset part, because you can't build a counter from latches. I fear, you're missing a clear concept of the overall design.assign ssclk=(keyclk)?0:sclk; - Altera_Forum
No errors,the report shows.
I use the signaltap 2 to monitor the signals' changes.the control signal's chang is correct,but the “j” changed not rightly. If using one input clock exclusively ,how should I modify my code? I would give more detail information tomorrow. The signaltap show ,the error is focused on “ssclk”. I divided the keyclk fuction and ssclk fuction. The project ran normally. When the keyclk have a posedge edge ,”j” add 6000 or 100 correctly. When I get them together ,the wrong appeared. It seemed that I hadn’t hold the ssclk signal low during during the keyclk hold high. The key error is here ,I think: always @(sclk)//avoid the conflict between keyclk and ssclk begin if(keyclk!=0) ssclk=0; else ssclk=sclk; end but why? - Altera_Forum
An edge sensitive always block must have only one input clock exclusively.
Generally, you should tell about the reported errors. - Altera_Forum
I hope somebody could help sovle it .Thanks.
