15 years agoHow to write a 88bit*4096 ram in VHDL?
Hi everyone,
I am trying to write a 88bit*4096 RAM all in VHDL. I defined an array as RAM and use package to initialize it. But there is an error when I compile it saying that *Error: Cannot convert all sets of registers into RAM megafunctions when creating nodes. The resulting number of registers remaining in design exceeds the number of registers in the device* Can anybody shed some light on how to fix the error? Thanks. Following is my VHDL code. /* RAM */ library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library work; use work.pack.all; entity RAM_test is port( clk : in std_logic; addr :in std_logic_vector(11 downto 0); cs : in std_logic; oe : in std_logic; data_i: in std_logic_vector(87 downto 0); data_o: out std_logic_vector(87 downto 0) ); end RAM_test; architecture Behavioral of RAM_test is signal ram1 : RamType := MEM_INIT; begin process(clk) begin if(clk'event and clk = '1') then if(cs = '0') then if(oe = '0') then data_o <= ram1(conv_integer(addr)); else ram1(conv_integer(addr)) <= data_i; end if; end if; end if; end process; end Behavioral; /*Package*/ library IEEE; use IEEE.STD_LOGIC_1164.ALL; package pack is type RamType is array (0 to 4095) of std_logic_vector(87 downto 0); constant MEM_INIT : RamType := ( /*content of RAM*/ ); end package pack;2 Replies
Quartus can be a bit tempremental in infering rams if you dont follow their coding guidlines properly. I have previously had problems (pre Q9, seems ok now) with some rams not being infered if there is no write-enable (some would work, some would not), and the response I got back was that "there is no write enable, so you're not following the coding guidelines).
With the OP could, I agree it should work, but I get the feeling it has built an asynchronous read mux in-front of the output register because of the if/else condition. It is always safer to completly separate your read and write logic, the way FvM suggested. - Altera_Forum
The original warning message is preceeded by this important line
--- Quote Start --- Info: RAM logic "ram1" is uninferred due to asynchronous read logic --- Quote End --- In my opinion, the analysis is incorrect. Quartus apparently doesn't like the nested if control signals. Try with this logically equivalent construct:if cs = '0' and oe = '0' then data_o <= ram1(conv_integer(addr)); end if; if cs = '0' and oe = '1' then ram1(conv_integer(addr)) <= data_i; end if;
