How to get again license file for old perpetual Quartus license?
- 4 years ago
Hi
Apologize for the inconvenience and delay in response since I was out of office recently.
- Is "one" license for IPS-EMBEDDED (approx. 1000$) valid for the whole company or just for one Workstation?
The "one" license has 2 types, floating and fixed. Depend on license type customer use. Fixed license is for 1 device per use (tie to one device). Floating licenses depend on number of seat that customer buy. no limitation on number of seats that customer can purchase.
- IPS-EMBEDDED is included in Quartus Prime Standard. Is it also included in Quartus Prime Lite?
The IPS-EMBEDDED is referring to (Nios® II Embedded Design Suite) only. Can refer here https://www.intel.com/content/dam/www/central-libraries/us/en/documents/quartus-prime-compare-editions-guide.pdf sorry if the statement confused.
Hope this clarify. Thanks
Alternative you could apply an Intel 90-Day Evaluation License that come with NIOS ll. Login to Intel® FPGA Self Service Licensing Center and request the Quartus evaluation free license here https://licensing.intel.com/
1) Go to Sign up for Evaluation or Free licenses
2) Select Intel® FPGA EVALUATION-LIC
3) # of Seats is always 1
4) Check the T&C box
5) Add the required options
6) Click Get License button
The license will be sent to email that you register with
Hello AR_A_Intel
For a short-term solution, I tried the proposed FPGA EVALUATION-LIC. It was successful for the Nios II, however, I still miss the TSE! Ok, for the moment, we can share the one machine with valid license. A longer-term solution must provide two independent workstations.
In the meantime, I found that the company bought IPS-EMBEDDED for approx. 1000$ years ago. (My colleague was convinced that it was included for free with some other software.) However, you @AR_A_Intel claimed here community.intel.com/t5/Intel-FPGA-Software-Installation/Type-of-license-for-Quartus-Prime-Embedded-IP-Suite-Development/m-p/1348254#M3500 that "IPS-EMBEDDED (Nios® II Embedded Design Suite) included with all QUaetus edition and no additional licenses are required."
Is that true for Quartus Prime Lite too?
Are the licenses per company or per workstation?
Regards, Thomas
