12 years ago
How to find largest value and its position in memory array?
As attachment... the memory array contains continuous input at every positive edge clock... these inputs are the outputs from the Altera FFT core... then i need to find the peak and its location... please help!!! thanks alot! from the attachment, the peak should be 45 and at memory_array [2].... and they should be shown at the outputs...
    --- Quote Start ---
    I suggested:
    always @ (posedge clock)
           begin
                 if (Enable)
                       begin
                            if (din > max_val)
                               begin
                                  max_val <= din;
                                  Q_val <= Q;
                               end
                              Q <= Q + 1;
           end
    end
    you need to take care of verilog syntax and rules as I am not good at it. You also need to take care of address latency.
    I also thought you are reading from memory but your code suggest are just writing to an array from din?? so which is'it? Anyway the code for din above should work in principle. what you do with din before/after is your focus.
    --- Quote End ---
    Thank you Kaz for your time :)
    I have tried the codes below, both with mem_array and without mem_array gave the same results which are wrong... (as picture attachment)
    module absolute(clock,Enable, d_in, max_value, max_location) ;
    input wire clock;
    input wire Enable;
    input wire [9:0] d_in;
    output reg [9:0] max_value;
    output reg [2:0] max_location;
    reg [9:0] max_val_tmp;
    reg [2:0] Q;
    //reg [9:0] mem_array [0:7];
    initial
    begin
    max_val_tmp = 0;
    end
    begin
    if (Enable)
    begin
    //mem_array[Q] <= d_in;
    if (d_in > max_val_tmp)
    begin
    max_value <= d_in;
    max_location <= Q;
    end
    Q <= Q + 1;
    end
    end
    endmodule
    **p.s. I need to write d_in into mem_array[Q] so that i can keep track on its location right?
    **another way i found something:
    "develop a verilog model for a peak detector that finds the maximum value in a sequence of 10-bit unsigned integers. a new number arrives at the input during a clock cycle when the data_en input is 1. if the new number is greater than the previously stored maximum value, the maximum value is updated with the new number; otherwise, it is unchanged. the stored maximum value is cleared to zero when the reset control input is 1. both data_en and reset are synchronous control inputs."
    I suggested:
           begin
                 if (Enable)
                       begin
                            if (din > max_val)
                               begin
                                  max_val <= din;
                                  Q_val <= Q;
                               end
                              Q <= Q + 1;
           end
    end
    --- Quote Start ---
    I have written the code in vhdl, which should work provided you look after type issues(signed...etc).
    You can write verilog on same basis.
    --- Quote End ---
    Hi Kaz, here is my code... but it's wrong... can you figure out my mistake?
    module absolute(clock,Enable, d_in, max_value) ;
    input wire clock;
    input wire Enable;
    reg [2:0] Q;
    initial
    begin
    max_val_tmp = mem_array[0];
    end
    begin
    if (Enable)
    begin
    if (mem_array[Q] > max_val_tmp)
    begin
    max_value <= mem_array[Q];
    end
    else
    begin
    max_value <= max_val_tmp;
    end
    Q <= Q + 1;
    end
    end
    endmodule
    --- Quote Start ---
    to get max of stream:
    in a clocked process:
    if din > max then
    max <= din;
    addr_of_max <= addr;
    end if;
    --- Quote End ---
    Hi Kaz, thanks for your reply... i know the concept... but I have no idea how to write it in Verilog code... though I have tried for several times, the output is wrong...
    if din > max then
    max <= din;
    end if;
