12 years agoHow to find largest value and its position in memory array?
As attachment... the memory array contains continuous input at every positive edge clock... these inputs are the outputs from the Altera FFT core... then i need to find the peak and its location... p...
12 years ago --- Quote Start --- to get max of stream: in a clocked process: if din > max then max <= din; addr_of_max <= addr; end if; --- Quote End --- Hi Kaz, thanks for your reply... i know the concept... but I have no idea how to write it in Verilog code... though I have tried for several times, the output is wrong...
