12 years agoHow to find largest value and its position in memory array?
As attachment... the memory array contains continuous input at every positive edge clock... these inputs are the outputs from the Altera FFT core... then i need to find the peak and its location... p...
12 years ago --- Quote Start --- I have written the code in vhdl, which should work provided you look after type issues(signed...etc). You can write verilog on same basis. --- Quote End --- Hi Kaz, here is my code... but it's wrong... can you figure out my mistake? module absolute(clock,Enable, d_in, max_value) ; input wire clock; input wire Enable; input wire [9:0] d_in; output reg [9:0] max_value; reg [9:0] max_val_tmp; reg [2:0] Q; reg [9:0] mem_array [0:7]; initial begin max_val_tmp = mem_array[0]; end always @ (posedge clock) begin if (Enable) begin mem_array[Q] <= d_in; if (mem_array[Q] > max_val_tmp) begin max_value <= mem_array[Q]; end else begin max_value <= max_val_tmp; end Q <= Q + 1; end end endmodule
