12 years agoHow to access FPGA Manager's Input & Output ?
I am using Cyclone V SoC Dev Kit.
I want to write a bare-metal program to access PUSH_BUTTON & DIP SWITCH on the board. I check the schematic of EVK, BUTTON & DIPSW is connect to FPGA manager's Input port. I have write a code as below, but can't read the input data from FPGA manager. How to make it available to access FPGA manager's Input ? ----------- Bare-metal source code ------------- // Download SOF before running program !!! int main(int argc, char** argv) { ALT_STATUS_CODE status = ALT_E_SUCCESS; ALT_FPGA_CFG_MODE_t mode; status = alt_fpga_init(); if(status != ALT_E_SUCCESS) return 1; if (alt_fpga_state_get() != ALT_FPGA_STATE_USER_MODE) { printf("\n not in USER_MODE. \n"); return 1; } status = alt_fpga_control_enable(); if(status != ALT_E_SUCCESS) return 1; while(1) { uint32_t input = alt_fpga_gpi_read(0xFFFFFFFF); printf(" input = 0x%X. \n", input); } return 0; } -------------- result --------- intput val = 0xFFFFFFFF intput val = 0xFFFFFFFF intput val = 0xFFFFFFFF6 Replies
Are you sure that in FPGA loaded .rbf or .sof with configuration, making routing to HPS of external pins ?
And similar program with HPS buttons work correctly ? - Altera_Forum
That's the point. I am not should that FPGA manager's input can directly connect to external pin.
What's the correct usage of FPGA input / output pins ? - Altera_Forum
I is the programmer, in principle circuit don't know !
May be method to insert your code in HWLIB-example, where LEDs was blinked -- there buttons MUST be available! And then cut small portions of big code, try compile and run -- while buttons may work, else undo cutting, cut another lines... In that way you get minimal program and understand, what current is bad. While not finded good documentation :) P.S. Try .svd files in debugger, as described in ug_soc_eds.pdf -- your code not need, and all GPIO may be visible after init. - Altera_Forum
Have you tried running that code with your finger on the button? Often board designs make push buttons active low so if you read 0xFFFF_FFFF when nothing is pushed and something like say 0xFFFF_FFFE when you push button 0 then it's behaving as I would expect with active low buttons.
Last but not least are you 100% sure those buttons and LEDs are connected to the FPGA manager GPIO and not just HPS GPIO? If the buttons/LEDs connect to FPGA I/O and are wired up to the HPS through the HPS Qsys component then yes, that's the FPGA manager GPIO you are using. If those buttons/LEDs connect to HPS I/O then you want to access the appropriate HPS GPIO component registers. - Altera_Forum
The Board has
1) 4 DIPSW for FPGA, 4 for HPS, 2) 4 PUSH_BUTTON for FPGA, and 2 PUSH_BUTTON for HPS 3) 4 LED for FPGA , 4 LED for HPS The PUSH_BUTTON or LED or DIPSW connect to FPGA can access via LW_AXI_BRIDGE. The LED of HPS is connect to GPIO 41~44, can access with GPIO registers of HPS. I am sure the PushButton & DipSwitch is connect to HPS's PIN according to Cyclone V SoC Dev Kit (Rev.C) schematic. You can find in www.rocketboards.org (http://www.rocketboards.org). http://www.rocketboards.org/pub/documentation/alterasocdevelopmentboard/c5_soc_devkit_c.pdf?t=1365712679 - search keyword "USER_PB_HPS", on page 5 Is there any example source code to access FPGA Manager 's GPIO ? https://www.alteraforum.com/forum/attachment.php?attachmentid=9117 - Altera_Forum
I am totally wrong.
The PUSH_BUTTON & DIPSW is connect to GPIO2 (Input Only PINs), not FPGA manager . Sorry for bothering everyone.
