12 years agoHow to access FPGA Manager's Input & Output ?
I am using Cyclone V SoC Dev Kit. I want to write a bare-metal program to access PUSH_BUTTON & DIP SWITCH on the board. I check the schematic of EVK, BUTTON & DIPSW is connect to FPGA man...
12 years agoHave you tried running that code with your finger on the button? Often board designs make push buttons active low so if you read 0xFFFF_FFFF when nothing is pushed and something like say 0xFFFF_FFFE when you push button 0 then it's behaving as I would expect with active low buttons.
Last but not least are you 100% sure those buttons and LEDs are connected to the FPGA manager GPIO and not just HPS GPIO? If the buttons/LEDs connect to FPGA I/O and are wired up to the HPS through the HPS Qsys component then yes, that's the FPGA manager GPIO you are using. If those buttons/LEDs connect to HPS I/O then you want to access the appropriate HPS GPIO component registers.
