11 years ago
How do I obtain a license file to enable the design security features
Hi folks,
How do I obtain a license file to enable the design security features such as configuration file encryption for Cyclone V?
jp
    Are u trying to generate an ekp file? How about using exactly the same command line described in page 10 an556? Not to forget the key identity in the key file too(page9). Other way to create ekp is from Quartus II GUI.Go to File>Convert Programming File..(explained in page 8 AN556).if u can see the bitstream encryption not greyed out in step 7(i),it means u already hv the encryption feature. Good luck!
    Do you have a subscription license? If yes, check whether you have the following line in the license file:
    FEATURE quartus_nonvolatile_encryption
    (as mentioned in license FAQ: https://www.altera.com/support/support-resources/download/licensing/q-and-a.html#c_07)
    If this line is missing, regenerate the license file in licensing center.
    If you're using web edition, i think you might need to contact your local distributor and ask them to request a license from altera. Hope this helps!
    My distributor (Digi-Key) says I don't need a license file. AN-556 says I do.
    Here is the error message I get when I try it:
    [pavan@kt-hw1 run1]$ /home/tools/altera/14.0/quartus/bin/quartus_cpf --64bit -e -k ./output_files/keyfile:key1 ./output_files/zorya_top.sof ./output_files/zorya_top.ekp
    Info: *******************************************************************
    Info: Running Quartus II 64-Bit Convert_programming_file
    Info: Version 14.0.0 Build 200 06/17/2014 SJ Full Version
    Info: Copyright (C) 1991-2014 Altera Corporation. All rights reserved.
    Info: Your use of Altera Corporation's design tools, logic functions
    Info: and other software and tools, and its AMPP partner logic
    Info: functions, and any output files from any of the foregoing
    Info: (including device programming or simulation files), and any
    Info: associated documentation or information are expressly subject
    Info: to the terms and conditions of the Altera Program License
    Info: Subscription Agreement, the Altera Quartus II License Agreement,
    Info: the Altera MegaCore Function License Agreement, or other
    Info: applicable license agreement, including, without limitation,
    Info: that your use is for the sole purpose of programming logic
    Info: devices manufactured by Altera and sold by Altera or its
    Info: authorized distributors. Please refer to the applicable
    Info: agreement for further details.
    Info: Processing started: Mon Apr 6 15:33:19 2015
    Info: Command: quartus_cpf --64bit -e -k ./output_files/keyfile:key1 ./output_files/zorya_top.sof ./output_files/zorya_top.ekp
    Error: Quartus II 64-Bit Convert_programming_file was unsuccessful. 0 errors, 0 warnings
    Error: Peak virtual memory: 373 megabytes
    Error: Processing ended: Mon Apr 6 15:33:20 2015
    Error: Elapsed time: 00:00:01
    Error: Total CPU time (on all processors): 00:00:02
    Any Ideas on what's wrong?
    jp
    May distributor (Digi-Key) says I don't need a license file. AN-556 says I do pn page 7.
    Here is the eroro message I get when I try it:
    Any thougts on what's wrong?
    jp
    Hi Folks,
    My distributor (Digi-Key) said I don't need a license file.....but here is the error message I get when I try to use Quartus for a CycloneV SE device:
    Any thoughts on what is wrong?
