11 years agoHow do I obtain a license file to enable the design security features
Hi folks, How do I obtain a license file to enable the design security features such as configuration file encryption for Cyclone V? Thanks, jp
11 years agoMy distributor (Digi-Key) says I don't need a license file. AN-556 says I do.
Here is the error message I get when I try it: [pavan@kt-hw1 run1]$ /home/tools/altera/14.0/quartus/bin/quartus_cpf --64bit -e -k ./output_files/keyfile:key1 ./output_files/zorya_top.sof ./output_files/zorya_top.ekp Info: ******************************************************************* Info: Running Quartus II 64-Bit Convert_programming_file Info: Version 14.0.0 Build 200 06/17/2014 SJ Full Version Info: Copyright (C) 1991-2014 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus II License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Mon Apr 6 15:33:19 2015 Info: Command: quartus_cpf --64bit -e -k ./output_files/keyfile:key1 ./output_files/zorya_top.sof ./output_files/zorya_top.ekp Error: Quartus II 64-Bit Convert_programming_file was unsuccessful. 0 errors, 0 warnings Error: Peak virtual memory: 373 megabytes Error: Processing ended: Mon Apr 6 15:33:20 2015 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:02 [pavan@kt-hw1 run1]$ Any Ideas on what's wrong? Thanks, jp
