11 years agoHow do I obtain a license file to enable the design security features
Hi folks, How do I obtain a license file to enable the design security features such as configuration file encryption for Cyclone V? Thanks, jp
11 years agoDo you have a subscription license? If yes, check whether you have the following line in the license file:
FEATURE quartus_nonvolatile_encryption (as mentioned in license FAQ: https://www.altera.com/support/support-resources/download/licensing/q-and-a.html#c_07) If this line is missing, regenerate the license file in licensing center. If you're using web edition, i think you might need to contact your local distributor and ask them to request a license from altera. Hope this helps!
