13 years ago
how can we enable and disable the particular modules we need in verilog?
i need to enable a particular module when some condition is satisfied and each module is selected on particular condition...i have written different modules now and i need to write a top module to connect all these modules under it...can you guys help me to solve this issue?....i tried to instantiate it in case statement but it s showing error...
    what you are saying is correct...the above is just an example...i have to make a control unit for alu...in alu i have done adder,multiplication and logical modules written separately in gate level...
    Generates will only work with static parameters define at synthesis time. So this won't work for you. What you could do is simply:
    assign out = (S == 2'b00) ? A&B :
    (S == 2'b01) ? A| B :
    (S == 2'b10) ? A^B : ~(A|B );
    this is the sample code i hav written...please check for an error ...
    module arithmetic20(A,B,S,out);
    input A,B;
    input [1:0]S;
    output out;
    generate
    if(S==2'b00)
    begin
    and1 a1(A,B,out);
    end
    endgenerate
    generate
    if(S==2'b01)
    begin
    or1 o1(A,B,out);
    end
    endgenerate
    generate
    if(S==2'b10)
    begin
    xor1 x1(A,B,out);
    end
    endgenerate
    generate
    if(S==2'b11)
    begin
    nor1 n1(A,B,out);
    end
    endgenerate
    endmodule
    module and1(A,B,out);
    input A,B;
    output out;
    wire out;
    assign out=A&B;
    endmodule
    module or1(A,B,out);
    input A,B;
    output out;
    wire out;
    assign out=(A|B);
    endmodule
    module xor1(A,B,out);
    input A,B;
    output out;
    wire out;
    assign out=(A^B);
    endmodule
    module nor1(A,B,out);
    input A,B;
    output out;
    wire out;
    assign out=(~(A|B));
    endmodule
    Don't expect further help if you don't provide more information about the error
    i tried it and could not get the code compiled...showing error...
    Use a Generate statement:
    generate
    if (someparam == 1) begin
    module module_i (
    ports
    end
    endgenerate
