13 years agohow can we enable and disable the particular modules we need in verilog?
i need to enable a particular module when some condition is satisfied and each module is selected on particular condition...i have written different modules now and i need to write a top module to co...
13 years agothis is the sample code i hav written...please check for an error ...
module arithmetic20(A,B,S,out); input A,B; input [1:0]S; output out; generate if(S==2'b00) begin and1 a1(A,B,out); end endgenerate generate if(S==2'b01) begin or1 o1(A,B,out); end endgenerate generate if(S==2'b10) begin xor1 x1(A,B,out); end endgenerate generate if(S==2'b11) begin nor1 n1(A,B,out); end endgenerate endmodule module and1(A,B,out); input A,B; output out; wire out; assign out=A&B; endmodule module or1(A,B,out); input A,B; output out; wire out; assign out=(A|B); endmodule module xor1(A,B,out); input A,B; output out; wire out; assign out=(A^B); endmodule module nor1(A,B,out); input A,B; output out; wire out; assign out=(~(A|B)); endmodule
