16 years ago
How can I use M9K RAM Memory in CycloneIII ??
Hello Everybody !..
I have seen in CIII datasheet that it has a different kind of RAM block called M9K, with higher frequency.
When I use "reg" is this a M9K??
I Use Verilog, How can i define and use this Memory Block?
A solution without using SOPC builder is preferred.
    --- Quote Start ---
    Use the MegaWizard plug-in manager if you want to create a ram-based shift register. It's under the "Memory Compiler" section.
    Jake
    --- Quote End ---
    thanks jakobjones, this was what i was looking for..
    --- Quote Start ---
    do you have problems to achieve your required clock speed ? Are you shift registers as register implemented ?
    Kind regards
    GPK
    --- Quote End ---
    Yes, My registers are defined as you mentioned above, like this.
    reg [0:7] my_ram[0:63]
    I don't have a trouble of speed, my current solution works fine but it would be fine it it could work faster.
    Jake
    --- Quote Start ---
    i have a solution of my project which has a lot of shift registers and i can have maximum 125 MHz in my algorithm.
    I saw that M9K type ram block has a very high frequency and wondered if i can increase my frequency..
    --- Quote End ---
    Kind regards
    GPK
    --- Quote Start ---
    you can do that by using :
    reg [0:7] my_ram[0:63] /* synthesis ramstyle = "M9K" */;
    But why do you want to specify the RAM implementation ?
    Knd regards
    GPK
    --- Quote End ---
    --- Quote Start ---
    Hello Everybody !..
    --- Quote End ---
    Knd regards
    GPK
