16 years agoHow can I use M9K RAM Memory in CycloneIII ??
Hello Everybody !.. I have seen in CIII datasheet that it has a different kind of RAM block called M9K, with higher frequency. When I use "reg" is this a M9K?? I Use Verilog, How can ...
16 years ago --- Quote Start --- Hi, do you have problems to achieve your required clock speed ? Are you shift registers as register implemented ? Kind regards GPK --- Quote End --- Yes, My registers are defined as you mentioned above, like this. reg [0:7] my_ram[0:63] I don't have a trouble of speed, my current solution works fine but it would be fine it it could work faster.
