16 years agoHow can I use M9K RAM Memory in CycloneIII ??
Hello Everybody !.. I have seen in CIII datasheet that it has a different kind of RAM block called M9K, with higher frequency. When I use "reg" is this a M9K?? I Use Verilog, How can ...
16 years ago --- Quote Start --- Use the MegaWizard plug-in manager if you want to create a ram-based shift register. It's under the "Memory Compiler" section. Jake --- Quote End --- thanks jakobjones, this was what i was looking for..
