16 years agoHow can I use M9K RAM Memory in CycloneIII ??
Hello Everybody !.. I have seen in CIII datasheet that it has a different kind of RAM block called M9K, with higher frequency. When I use "reg" is this a M9K?? I Use Verilog, How can ...
16 years ago --- Quote Start --- i have a solution of my project which has a lot of shift registers and i can have maximum 125 MHz in my algorithm. I saw that M9K type ram block has a very high frequency and wondered if i can increase my frequency.. --- Quote End --- Hi, do you have problems to achieve your required clock speed ? Are you shift registers as register implemented ? Kind regards GPK
