16 years agohow can i get about 100Mbps~200Mbps TCP traffic using Ethernet ?
Hi :
I want to use Ethernet to transmit huge of data (after AD processing) to PC. It is better to get about 100Mbps~200Mbps TCP traffic .I think it's hard for Nios II system to get this speeed . Do you have any feasible scheme about this problem ? Does anyone have achieved this speed ? Now ,I have cyclone III and Stratix II ,LAN91C111 and Triple speed Ethernet IP CORE. Best Regards -poseidon13 Replies
--- Quote Start --- application note 440 (http://www.altera.com/literature/an/an440.pdf), page 18, gives some results that you can expect with a Nios CPU on a Stratix II. --- Quote End --- If i use DMA,do you think this schema could be more faster? - Altera_Forum
--- Quote Start --- application note 440 (http://www.altera.com/literature/an/an440.pdf), page 18, gives some results that you can expect with a Nios CPU on a Stratix II. --- Quote End --- Thank you Daixiwen .I will take a gook look at this Document. Best Regard -poseidon - Altera_Forum
