16 years agohow can i get about 100Mbps~200Mbps TCP traffic using Ethernet ?
Hi : I want to use Ethernet to transmit huge of data (after AD processing) to PC. It is better to get about 100Mbps~200Mbps TCP traffic .I think it's hard for Nios II system to get this speeed...
16 years ago --- Quote Start --- application note 440 (http://www.altera.com/literature/an/an440.pdf), page 18, gives some results that you can expect with a Nios CPU on a Stratix II. --- Quote End --- If i use DMA,do you think this schema could be more faster?
