17 years agoHow can I generate a reset signal?
Many IC need a reset signal to initialation, but when I write codes in FPGA, the Quartus will stick the signal to a fixed level, the code is as below: input clk; output reset; reg reset;...
17 years agoObviously, the power-on self-reset is only meaningful for systems that don't have a reset input. I completely agree, that a reset input is the preferred way. If you don't have it, you can force the power on condition also by reloading the FPGA through JTAG, a straightforward and simple method in my opinion.
On the other hand, if the system has a reset input, you should care that power-on (or reconfigure) condition is also triggering the same behaviour as reset. Otherwise, you may need to cycle the power in debugging, although you provided a reset ...
